System Settings
Hold
, and select
- Language
Sets the language displayed on the watch.
- Display
Sets the display timeout and brightness (Customizing the Display Settings).
- Alert Vibration
Turns vibration on or off and sets the vibration intensity.
- Phone
Allows you to pair and sync your phone (Pairing Your Phone).
- Passcode
Sets a four-digit passcode to secure your personal information when the watch is not on your wrist (Setting Your Watch Passcode).
- Format
Sets the measurement units used to display data (Changing the Units of Measure).
- Reset
Allows you to reset the default settings or delete personal data and reset the settings (Restoring All Default Settings).
NOTE: If you have set up a Garmin Pay™ wallet, restoring default settings also deletes the wallet from your device. - About
Displays the unit ID, software version, regulatory information, and license agreement.
Hold
- Select .
- Select Brightness to set the brightness level of the screen.
- Select General Use or During Activity.
Select an option:
Select Gesture to turn on the screen by raising and turning your arm to look at your wrist.
Select Gesture Sensitivity to adjust the gesture sensitivity to turn on the display more or less often.
Select Timeout to set the length of time before the screen turns off.
- Select During Sleep.
Select an option:
Select Watch Face to set the watch face to dim during your defined sleep window.
Select Brightness to set the brightness level of the screen during your defined sleep window.
Select Timeout to set the length of time before the screen turns off during your defined sleep window.
You can customize units of measure for distance, pace and speed, elevation, and more.
Hold
- Select .
Select an option.
Select Units to set the primary units of measure for the watch.
Select Pace/Speed to display your pace or speed in miles or kilometers during a timed activity.
If you enter your passcode incorrectly three times, the watch locks temporarily. After five incorrect attempts, the watch locks until you reset your passcode in the Garmin Connect™ app. If you have not paired your watch with your phone, the watch deletes your data and resets to the factory default settings after five incorrect attempts.
You can set up a watch passcode to secure your personal information when the watch is not on your wrist. If you are using the Garmin Pay feature, the watch uses the same four-digit passcode required to open your wallet (Garmin Pay).
Hold
- Select .
- Enter a four-digit passcode.
The next time you remove the watch from your wrist, you must enter the passcode before you can view any information.
Changing Your Watch Passcode
You must know your existing watch passcode to change it. If you forget your passcode or make too many incorrect passcode attempts, you must reset it in the Garmin Connect app.
Hold
- Select .
- Enter your existing four-digit passcode.
- Enter a new four-digit passcode.
