Pairing Your Phone
To set up the Lily® 2 Active watch, it must be paired directly through the Garmin Connect™ app, instead of from the Bluetooth® settings on your phone.
  1. During the initial setup on your watch, select Checkmark symbol when you are prompted to pair with your phone.
    NOTE: If you previously skipped the pairing process, you can hold Lower-right button, and select System > Phone > Pair Phone to manually enter pairing mode.
  2. Scan the QR code with your phone, and follow the on-screen instructions to complete the pairing and setup process.
GUID-FABAD210-C716-48B1-AB1D-A09097F1CED4 v3
May 2026
