Broadcasting Heart Rate Data to Garmin Devices
You can broadcast your heart rate data from your Lily® 2 Active watch and view it on paired Garmin® devices. For example, you can broadcast your heart rate data to an Edge® bike computer while cycling.
NOTE: Broadcasting heart rate data decreases battery life.
  1. Hold Upper-right button to view the controls menu.
    NOTE: You can customize the controls menu (Customizing the Controls Menu).
  2. Select Heart rate broadcast symbol.
  3. Press Upper-right button.
    The Lily 2 Active watch starts broadcasting your heart rate data.
    NOTE: The time appears on the screen while broadcasting heart rate data.
  4. Pair your Lily 2 Active watch with your Garmin ANT‍+® compatible device.
    NOTE: The pairing instructions differ for each Garmin compatible device. See your owner's manual.
  5. Repeat steps 1 through 3 to stop broadcasting your heart rate data.
GUID-FABAD210-C716-48B1-AB1D-A09097F1CED4 v3
May 2026
