Customizing the Controls Menu
You can add, remove, and change the order of the menu options in the controls menu.
  1. From the watch face, hold Upper-right button to view the controls menu.
    The controls menu appears.
  2. Hold Lower-right button.
    The controls menu switches to edit mode.
  3. Select an option:
    • To change the location of a menu option in the controls menu, drag the option to a new location.
    • To remove a menu option from the controls menu, drag the option to Delete symbol.
  4. If necessary, select Plus symbol to add a menu option to the controls menu.
    NOTE: This option is available only after you remove at least one menu option from the controls menu.
GUID-FABAD210-C716-48B1-AB1D-A09097F1CED4 v3
May 2026
