Putting On the Heart Rate Monitor
Put on a medium or high support sports bra with a tight fitting band.
The proper sports bra fit will reduce heart rate monitor movement, maintain good skin-to-electrode contact, and ensure comfort (HRM-Fit Sports Bra Guide ).
Wet the electrodes
on the back of the heart rate monitor to create a strong connection between your chest and the transmitter.
- Open the clips on the front of the heart rate monitor.
Insert the sports bra band fabric into the center clip
The fabric must lay flat inside the clip.
Close the clip on to the fabric until it clicks into place.
Repeat steps 4 and 5 with the side clips
TIP:As you are closing the side clips, use your other hand to lightly pull the sports bra band towards the center.
Make sure the
HRM-Fit™ heart rate monitor is secured in place, lays flat beneath the sports bra band, and is compressed against the skin.
After you put on the heart rate monitor, it is active and sending data.
Parent Topic: Heart Rate Monitor Instructions
