Upgrading Your Rally 100 to a Dual Sensing System
Before you install the new right pedal, the left pedal must be paired and connected to a compatible Edge® device or the Garmin Connect™ app.
- Review the Rally™ installation instructions (Installing the Rally Components).
- Remove the existing right pedal.
- Install the new right pedal (Installing the Pedals).
- Rotate the crank arm.
Select an option to connect the right pedal to the left pedal:
From your compatible Edge device, select , select your sensor, select , and enter the sensor ID found on the pedal.
From the Garmin Connect app device settings, enable the Right Pedal, and enter the sensor ID found on the pedal.
Parent Topic: Appendix
