Navigating Using TracBack
While recording an activity, you can navigate back to the beginning of your path.
NOTE: This can be helpful if you get lost and need to find your way back to camp or the trail head.
  1. From the home screen, hold BACK to open the action menu.
  2. Select Navigate > TracBack.
  3. Select Edit TracBack.
  4. Select the destination, and select the time interval.
  5. Press Down arrow to scroll through the recorded points.
  6. Press OK to select a point to navigate to.
  7. Select the Direct Path toggle to take the most direct path back to start.
  8. Press BACK.
  9. Select Navigate > Start to start navigating.
GUID-F31CF821-79A9-46E5-A45B-8765F918488F v2
April 2026
