Deleting a Weather Location
You must set the weather location before you can delete it (Setting the Weather Location).
You can delete an expired forecast or a forecast for a location that you no longer need.
  1. From the home page, press Up arrow or Down arrow to scroll through the apps.
  2. Select Weather.
  3. Press OK to open the options menu.
  4. Select Change Location > Edit > Select a Location > Discard.
GUID-F31CF821-79A9-46E5-A45B-8765F918488F v2
April 2026
