Installing the Antenna on the Group Ride Mount
NOTE: The mounted antenna must be at least 4 cm (1.57 in.) away from the nearest roll bar or metal surface to avoid radio interference.
For the best range performance, use the external antenna mount. You can mount the antenna directly onto the Group Ride mount when it is not possible to use the external antenna mount (Mounting the Antenna).
Screw down and tighten the antenna onto the Group Ride mount.
Group ride radio with antenna being installed
Copyright © Garmin. All rights reserved.GUID-F0AC3576-CD83-465E-983D-7AD585ADB59E v6
