Using Voice Commands
  1. Select an option:
    • From the watch face, press Line drawing of the watch with a top button callout, and select Voice Command.
    • Hold Line drawing of the watch with a top button callout, and select Voice Command.
    NOTE: You can customize the controls menu (Customizing the Controls Menu).
  2. Say a voice command for the watch to perform (Watch Voice Commands).
The voice command system is designed to detect natural speech. This is a list of commonly used voice commands, but the watch does not require these exact phrases. You can try saying variations of these commands in a way that is natural to you. Go to garmin.com/voicecommand/tips for voice command tips and troubleshooting information.
Voice Help Command
Function
What can I say?
Shows a list of common voice commands
Device and Screen Functions
Voice Command
Function
Disable do not disturb
Disables do not disturb mode to dim the screen and disable alerts and notifications.
Turn on airplane mode
Enables airplane mode to turn off all wireless communications.
Increase brightness
Raises the brightness level.
Decrease brightness
Lowers the brightness level.
Set brightness to 80
Sets the brightness level to a specified percent. Available numbers are 0-100%.
Clock Functions
Voice Command
Function
Set a timer for fifteen minutes
Sets a countdown timer for the specified time.
Pause timer
Pauses the currently running countdown timer.
Resume timer
Resumes the paused countdown timer.
Cancel timer
Cancels the currently running countdown timer.
Start stopwatch
Starts the stopwatch.
Stop stopwatch
Stops the stopwatch.
Wake me up at 3:15 a.m.
Sets a one-time alarm for the specified time.
App and Activity Functions
Voice Command
Function
Show me the weather
Opens the weather app.
Start a run
Starts a Run activity.
NOTE: The apps and activities listed are examples, but you can control all of the default apps and activities with voice commands (Apps), (Activities).
Media Functions
Voice Command
Function
Change volume to 8
Adjusts the volume to the specified level. Available numbers are 0-10 or 0-100%.
Increase volume
Raises the audio volume.
Decrease volume
Lowers the audio volume.
Play music
Plays the currently selected media.
Next song
Plays the next media track.
Previous song
Plays the previous media track.
Pause music
Pauses the currently playing media.
Mute
Silences all audio.
Unmute
Turns on all audio.
GUID-ED045F09-4EC3-41F5-AAAC-42B3A3836894 v3
July 2026
