Sharing Data with Garmin Share
Before you can use this feature, you must have Bluetooth® technology enabled on both compatible devices, and they must be within 3 m (10 ft.) of each other. When prompted, you must also consent to share your data with other Garmin® devices using Garmin Share.
Your Descent™ dive computer can send and receive data when connected to another compatible Garmin device (Receiving Data with Garmin Share). You can also transfer your data between different devices. For example, you can share a favorite location from your compatible Garmin watch to your dive computer.
  1. From the home screen, scroll down to the extended app list.
  2. Select Garmin Share > Share.
  3. Select at least one item.
  4. Select Share.
  5. Wait while the device locates compatible devices.
  6. Select a device.
  7. If necessary, confirm the six-digit PIN matches on both devices, and select Check mark.
  8. Wait while the devices transfer the data.
  9. Press ENTER.
  10. Select Share Again to share the same items with another user (optional).
  11. Select Done.
GUID-EBD9D9CA-112E-4044-A2C9-354D565B9A10 v3
September 2026
