Receiving Data with Garmin Share
Before you can use this feature, you must have Bluetooth® technology enabled on both compatible devices, and they must be within 3 m (10 ft.) of each other. When prompted, you must also consent to share your data with other Garmin® devices using Garmin Share.
  1. From the home screen, scroll down to the extended app list.
  2. Select Garmin Share.
  3. Wait while the device locates compatible devices in range.
  4. Select Accept.
  5. If necessary, confirm the six-digit PIN matches on both devices, and select Check mark.
  6. Wait while the devices transfer the data.
  7. Press ENTER.
  8. Select Done.
GUID-EBD9D9CA-112E-4044-A2C9-354D565B9A10 v3
September 2026
