Changing the Map Region
When the device is connected to a Wi‑Fi® network, you can download new map regions directly onto the device.
  1. Select Apps icon > Map Manager > Manage Device Maps.
  2. Select an option:
    • To remove a map region, select the region, and select Remove.
    • To install a new map region to the device's internal memory, select the region, and select Install to Device.
    • To install a new map region to a memory card (Installing a Memory Card for Maps and Data), select the region, and select Install to the Memory Card.
    As you add or remove new regions, a bar at the top of the page displays the available storage space on the device.
  3. After you have finished adding and removing map regions, select Apply.
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
