Adding a Stop to Your Route
Before you can add a stop to your route, you must be navigating a route (Starting a Route).
You can add stops to the middle or end of your route. For example, you can add a fuel station as the next destination in your route.
TIP: To create complex routes with multiple destinations or scheduled stops, you can use the route planner to plan, schedule, and save a route (Planning a Route).
  1. From the map, select Back to previous page > Search.
  2. Search for a location (Finding and Saving Locations).
  3. Select a location.
  4. Select Go!.
  5. Select an option:
    • To stop the current route and start a new route to the location, select Start New Route.
    • To add the location as the next destination in your route, select Add as Next Stop.
    • To add the location to the end of your route, select Add as Last Stop.
    • To add the location and edit the order of destinations in your route, select Add to Active Route.
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
