Routes
A route is a path from your current location to one or more destinations.
  • For off-road use, you can set the device to calculate point-to-point routes in a straight line.
  • The device calculates a recommended route to your destination based on the preferences you set, including the route calculation mode and avoidances (Avoiding Delays, Tolls, and Areas).
  • The device can automatically avoid roads that are not appropriate for the active vehicle profile.
  • You can start navigating to your destination quickly using the recommended route, or you can select an alternate route (Starting a Route).
  • If there are specific roads you need to use or avoid, you can customize the route (Shaping Your Route).
  • You can add multiple destinations to a route (Adding a Stop to Your Route).
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
