Channel View
Alpha® navigators and dog collar devices broadcast data over individual channels. Channels are identified using unique IDs. You can use the channel view to see which channels are in use and which channels are available.
Changing the Dog ID
Before you can change the dog ID, the collar must be turned on and within range of the navigator.
If you are experiencing interference from other collars or navigators in the area, you might need to change the ID for the dog.
  1. Select Apps icon > Channel View > My Devices.
  2. Select a dog, and select Yes.
    The navigator scans for an ID free of interference and selects it automatically.
    TIP: If necessary, you can select Choose an ID to select an available ID.
If another handheld device is tracking this dog, for best results, remove the dog from the device, and use the track and control codes to add the dog again (Adding a Dog Using the Track and Control Codes).
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
