Adding a Dog Using the Track and Control Codes
NOTE: This feature varies based on dog collar device type and feature availability in your area.
Before you can add a dog using the track and control codes, the dog owner must find the track and control codes (Finding the Dog ID and Track and Control Codes) and tell them to you.
You can use track and control codes to authorize a handheld device to interact with your dog collar device. If you are not near the dog you want to add or you cannot put the collar into pairing mode, you can add the dog using the track and control codes.
  1. Select Dog list icon > Add.
  2. Select Enter Track or Control Code.
  3. Enter the track or control code for the collar, and select Done.
    The dog’s track code allows you to track the dog. The dog’s control code allows you to both track and train the dog.
  4. Enter the name of the dog, and select Done.
GUID-E4961C4C-A75C-4277-A125-70E674AFA2F4 v3
December 2025
