Resetting the Pedals Using a Computer
  1. If you do not have the Garmin Express™ application installed on your computer, go to garmin.com/express and follow the on-screen instructions (Installing Garmin Express).
  2. Open the Express app Garmin Express application.
  3. Connect the left pedal to your computer using the magnetic charging adapter and the USB-C® cable.
  4. In the Garmin Express application, click Add a Device.
    The Garmin Express application searches for your device and displays the device name and serial number.
  5. Click Add Device, and follow the on-screen instructions.
  6. Select Tools & Content.
  7. In the Utilities tab, select Enable Pairing Mode.
  8. Disconnect the pedal from the computer.
    The status LED flashes Magenta (magenta) to indicate that the pedals are in pairing mode.
After resetting the pedals to secure pairing mode, you should immediately pair them with the Garmin Connect™ app (Pairing with the Garmin Connect App).
GUID-E17670DF-416F-455E-8444-29845F375EBD v2
August 2026
