Restoring Settings to Factory Defaults
Restoring settings to factory defaults does not reset the pedals to secure pairing mode. If your pedals have lost their connection to the Garmin Connect™ app, you must reset them to secure pairing mode (Resetting the Pedals).
  1. Rotate the cranks to wake up the pedals.
    NOTE: In a Rally™ 210 system, both pedals must be turned on to perform a factory reset.
  2. In the Garmin Connect app, select Menu symbol > Garmin Devices > Rally 110/210 > System.
  3. Select Factory Reset.
    While resetting the pedals, the status LED flashes Red Orange Green (red, orange, green).
After completing the factory reset, the pedals go into secure pairing mode, and the status LED flashes Magenta (magenta).
NOTE: You must delete the pedals from your phone Bluetooth® settings before pairing the pedals with the Garmin Connect app again (Pairing with the Garmin Connect App).
GUID-E17670DF-416F-455E-8444-29845F375EBD v2
August 2026
