Alerts
You can set alerts for each activity, which can help you to train toward specific goals, to increase your awareness of your environment, and to navigate to your destination. Some alerts are available only for specific activities. There are three types of alerts: event alerts, range alerts, and recurring alerts.
Event alert
An event alert notifies you once. The event is a specific value. For example, you can set the device to alert you when you reach a specified elevation.
Range alert
A range alert notifies you each time the device is above or below a specified range of values. For example, you can set the device to alert you when your heart rate is below 60 beats per minute (bpm) and over 210 bpm.
Recurring alert
A recurring alert notifies you each time the device records a specified value or interval. For example, you can set the device to alert you every 30 minutes.
Alert Name
Alert Type
Description
Cadence
Range
You can set minimum and maximum cadence values.
Calories
Event, recurring
You can set the number of calories.
Custom
Event, recurring
You can select an existing message or create a custom message and select an alert type.
Distance
Recurring
You can set a distance interval.
Elevation
Range
You can set minimum and maximum elevation values.
Heart Rate
Range
You can set minimum and maximum heart rate values or select zone changes. See About Heart Rate Zones and Heart Rate Zone Calculations.
Pace
Range
You can set minimum and maximum pace values.
Proximity
Event
You can set a radius from a saved location.
Run/Walk
Recurring
You can set timed walking breaks at regular intervals.
Speed
Range
You can set minimum and maximum speed values.
Stroke Rate
Range
You can set high or low strokes per minute.
Time
Event, recurring
You can set a time interval.
Copyright © Garmin. All rights reserved.GUID-DF83D4F4-0E7B-44D5-9F6C-59C20665AC00 v5
