Calibrating the Barometric Altimeter
Your device was already calibrated at the factory, and the device uses automatic calibration at your GPS starting point by default. You can manually calibrate the barometric altimeter if you know the correct elevation.
  1. Hold MENU.
  2. Select Settings > Sensors & Accessories > Altimeter.
  3. Select an option:
    • To calibrate automatically from your GPS starting point, select Auto Cal., and select an option.
    • To enter the current elevation manually, select Calibrate > Yes.
    • To enter the current elevation from the digital elevation model, select Calibrate > Use DEM.
      NOTE: Some devices require a phone connection to use DEM for calibration.
    • To enter the current elevation from your GPS starting point, select Calibrate > Use GPS.
Copyright © Garmin. All rights reserved.GUID-DF83D4F4-0E7B-44D5-9F6C-59C20665AC00 v5
