Locating a Lost Mobile Device
You can use this feature to help locate a lost mobile device that is paired using Bluetooth® technology and currently within range.
NOTE: You can add options to the controls menu (Customizing the Controls Menu).
  1. Hold CTRL to view the controls menu.
  2. Select Find my phone.
    The Instinct® device begins searching for your paired mobile device. An audible alert sounds on your mobile device, and the Bluetooth signal strength appears on the Instinct device screen. The Bluetooth signal strength increases as you move closer to your mobile device.
  3. Press BACK to stop searching.
Copyright © Garmin. All rights reserved.GUID-DF83D4F4-0E7B-44D5-9F6C-59C20665AC00 v5
