Data Fields
- %HRR
The percentage of heart rate reserve (maximum heart rate minus resting heart rate).
- 24-Hour Max.
The maximum temperature recorded in the last 24 hours from a compatible temperature sensor.
- 24-Hour Min.
The minimum temperature recorded in the last 24 hours from a compatible temperature sensor.
- Ambient Press.
The uncalibrated ambient pressure.
- Average HR
The average heart rate for the current activity.
- Average Pace
The average pace for the current activity.
- Average Swolf
The average swolf score for the current activity. Your swolf score is the sum of the time for one length plus the number of strokes for that length (Swim Terminology). In open water swimming, 25 meters is used to calculate your swolf score.
- Avg. %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current activity.
- Avg. Ascent
The average vertical distance of ascent since the last reset.
- Avg. Cadence
Cycling. The average cadence for the current activity.
- Avg. Cadence
Running. The average cadence for the current activity.
- Avg. Descent
The average vertical distance of descent since the last reset.
- Avg. Lap Time
The average lap time for the current activity.
- Avg. Moving Speed
The average speed when moving for the current activity.
- Avg. Nautical Speed
The average speed in knots for the current activity.
- Avg. Overall Speed
The average speed for the current activity, including both moving and stopped speeds.
- Avg. Speed
The average speed for the current activity.
- Avg. Strk/Len
The average number of strokes per pool length during the current activity.
- Avg. Strk Rate
Swimming. The average number of strokes per minute (spm) during the current activity.
- Avg. Strk Rate
Paddle sports. The average number of strokes per minute (spm) during the current activity.
- Avg Dist Per Stk
Swimming. The average distance traveled per stroke during the current activity.
- Avg Dist Per Stk
Paddle sports. The average distance traveled per stroke during the current activity.
- Avg HR %Max.
The average percentage of maximum heart rate for the current activity.
- Baro. Pressure
The calibrated current pressure.
- Battery Level
The remaining battery power.
- Bearing
The direction from your current location to a destination. You must be navigating for this data to appear.
- Cadence
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
- Cadence
Running. The steps per minute (right and left).
- Calories
The amount of total calories burned.
- Compass Hdg.
The direction you are moving based on the compass.
- Course
The direction from your starting location to a destination. Course can be viewed as a planned or set route. You must be navigating for this data to appear.
- Dest. Wpt
The last point on the route to the destination. You must be navigating for this data to appear.
- Dist. Per Stroke
Paddle sports. The distance traveled per stroke.
- Dist. Remaining
The remaining distance to the final destination. You must be navigating for this data to appear.
- Distance
The distance traveled for the current track or activity.
- Distance To Next
The remaining distance to the next waypoint on the route. You must be navigating for this data to appear.
- Elapsed Time
The total time recorded. For example, if you start the timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
- Elevation
The altitude of your current location above or below sea level.
- Estimated Total Distance
The estimated distance from the start to the final destination. You must be navigating for this data to appear.
- ETA
The estimated time of day when you will reach the final destination (adjusted to the local time of the destination). You must be navigating for this data to appear.
- ETA at Next
The estimated time of day when you will reach the next waypoint on the route (adjusted to the local time of the waypoint). You must be navigating for this data to appear.
- ETE
The estimated time remaining until you reach the final destination. You must be navigating for this data to appear.
- Floors Climbed
The total number of floors climbed up for the day.
- Floors Descended
The total number of floors climbed down for the day.
- Floors per Minute
The number of floors climbed up per minute.
- Glide Ratio
The ratio of horizontal distance traveled to the change in vertical distance.
- Glide Ratio Dest.
The glide ratio required to descend from your current position to the destination elevation. You must be navigating for this data to appear.
- GPS
The strength of the GPS satellite signal.
- GPS Elevation
The altitude of your current location using GPS.
- GPS Heading
The direction you are moving based on GPS.
- Grade
The calculation of rise (elevation) over run (distance). For example, if for every 3 m (10 ft.) you climb you travel 60 m (200 ft.), the grade is 5%.
- Heading
The direction you are moving.
- Heart Rate
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
- HR %Max.
The percentage of maximum heart rate.
- HR Zone
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
- Int. Avg. %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
- Int. Avg. %Max.
The average percentage of maximum heart rate for the current swim interval.
- Int. Avg. HR
The average heart rate for the current swim interval.
- Int. Distance
The distance traveled for the current interval.
- Int. Max. %HRR
The maximum percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
- Int. Max. %Max.
The maximum percentage of maximum heart rate for the current swim interval.
- Int. Max. HR
The maximum heart rate for the current swim interval.
- Int. Pace
The average pace for the current interval.
- Int. Swolf
The average swolf score for the current interval.
- Interval Lengths
The number of pool lengths completed during the current interval.
- Interval Time
The stopwatch time for the current interval.
- Int Strk/Len
The average number of strokes per pool length during the current interval.
- Int Strk Rate
The average number of strokes per minute (spm) during the current interval.
- Int Strk Type
The current stroke type for the interval.
- L. Lap HR %Max.
The average percentage of maximum heart rate for the last completed lap.
- L. Lap Stk. Rate
Swimming. The average number of strokes per minute (spm) during the last completed lap.
- L. Lap Stk. Rate
Paddle sports. The average number of strokes per minute (spm) during the last completed lap.
- L. Lap Strokes
Swimming. The total number of strokes for the last completed lap.
- L. Lap Strokes
Paddle sports. The total number of strokes for the last completed lap.
- L. Lap Swolf
The swolf score for the last completed lap.
- L. Len. Stk. Rate
The average number strokes per minute (spm) during the last completed pool length.
- L. Len. Stk. Type
The stroke type used during the last completed pool length.
- L. Len. Strokes
The total number of strokes for the last completed pool length.
- Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current lap.
- Lap Ascent
The vertical distance of ascent for the current lap.
- Lap Cadence
Cycling. The average cadence for the current lap.
- Lap Cadence
Running. The average cadence for the current lap.
- Lap Descent
The vertical distance of descent for the current lap.
- Lap Distance
The distance traveled for the current lap.
- Lap Dist Per Stk
Swimming. The average distance traveled per stroke during the current lap.
- Lap Dist Per Stk
Paddle sports. The average distance traveled per stroke during the current lap.
- Lap HR
The average heart rate for the current lap.
- Lap HR %Max.
The average percentage of maximum heart rate for the current lap.
- Lap Pace
The average pace for the current lap.
- Laps
The number of laps completed for the current activity.
- Lap Speed
The average speed for the current lap.
- Lap Strk Rate
Swimming. The average number of strokes per minute (spm) during the current lap.
- Lap Strk Rate
Paddle sports. The average number of strokes per minute (spm) during the current lap.
- Lap Strokes
Swimming. The total number of strokes for the current lap.
- Lap Strokes
Paddle sports. The total number of strokes for the current lap.
- Lap Swolf
The swolf score for the current lap.
- Lap Time
The stopwatch time for the current lap.
- Last Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the last completed lap.
- Last Lap Ascent
The vertical distance of ascent for the last completed lap.
- Last Lap Cad.
Cycling. The average cadence for the last completed lap.
- Last Lap Cad.
Running. The average cadence for the last completed lap.
- Last Lap Descent
The vertical distance of descent for the last completed lap.
- Last Lap Dist.
The distance traveled for the last completed lap.
- Last Lap HR
The average heart rate for the last completed lap.
- Last Lap Pace
The average pace for the last completed lap.
- Last Lap Speed
The average speed for the last completed lap.
- Last Lap Time
The stopwatch time for the last completed lap.
- Last Len. Pace
The average pace for your last completed pool length.
- Last Len. Swolf
The swolf score for the last completed pool length.
- Lengths
The number of pool lengths completed during the current activity.
- L Lap Dist P Stk
Swimming. The average distance traveled per stroke during the last completed lap.
- L Lap Dist P Stk
Paddle sports. The average distance traveled per stroke during the last completed lap.
- Max. Ascent
The maximum rate of ascent in feet per minute or meters per minute since the last reset.
- Max. Descent
The maximum rate of descent in meters per minute or feet per minute since the last reset.
- Max. Elevation
The highest elevation reached since the last reset.
- Max. Nautical Speed
The maximum speed in knots for the current activity.
- Maximum Speed
The top speed for the current activity.
- Min. Elevation
The lowest elevation reached since the last reset.
- Moving Time
The total time moving for the current activity.
- Nautical Dist
The distance traveled in nautical meters or nautical feet.
- Nautical Speed
The current speed in knots.
- Next Waypoint
The next point on the route. You must be navigating for this data to appear.
- Off Course
The distance to the left or right by which you have strayed from the original path of travel. You must be navigating for this data to appear.
- Pace
The current pace.
- Repeat On
The timer for the last interval plus the current rest (pool swimming).
- Reps
During a strength training activity, the number of repetitions in a workout set.
- Rest Timer
The timer for the current rest (pool swimming).
- Set Timer
During a strength training activity, the amount of time spent in the current workout set.
- Speed
The current rate of travel.
- Stopped Time
The total time stopped for the current activity.
- Stroke Rate
Swimming. The number of strokes per minute (spm).
- Stroke Rate
Paddle sports. The number of strokes per minute (spm).
- Strokes
Swimming. The total number of strokes for the current activity.
- Strokes
Paddle sports. The total number of strokes for the current activity.
- Sunrise
The time of sunrise based on your GPS position.
- Sunset
The time of sunset based on your GPS position.
- Swim Time
The swimming time for the current activity, not including rest time.
- Temperature
The temperature of the air. Your body temperature affects the temperature sensor. You can pair a tempe™ sensor with your device to provide a consistent source of accurate temperature data.
- Time in Zone
The time elapsed in each heart rate zone.
- Time of Day
The time of day based on your current location and time settings (format, time zone, daylight saving time).
- Timer
The current time of the countdown timer.
- Time to Next
The estimated time remaining before you reach the next waypoint in the route. You must be navigating for this data to appear.
- Total Ascent
The total elevation distance ascended since the last reset.
- Total Descent
The total elevation distance descended since the last reset.
- V Dist to Dest
The elevation distance between your current position and the final destination. You must be navigating for this data to appear.
- Vert. Spd.
The rate of ascent or descent over time.
- Vert Spd to Tgt
The rate of ascent or descent to a predetermined altitude. You must be navigating for this data to appear.
- VMG
The speed at which you are closing on a destination along a route. You must be navigating for this data to appear.
