Customizing the Data Screens
You can show, hide, and change the layout and content of data screens for each activity.
  1. Hold MENU.
  2. Select Settings > Activities & Apps.
  3. Select the activity to customize.
  4. Select the activity settings.
  5. Select Data Screens.
  6. Select a data screen to customize.
  7. Select an option:
    • Select Layout to adjust the number of data fields on the data screen.
    • Select a field to change the data that appears in the field.
    • Select Reorder to change the location of the data screen in the loop.
    • Select Remove to remove the data screen from the loop.
  8. If necessary, select Add to add a data screen to the loop.
    You can add a custom data screen, or select one of the predefined data screens.
Copyright © Garmin. All rights reserved.GUID-DF83D4F4-0E7B-44D5-9F6C-59C20665AC00 v5
