Managing Language Files
You can remove language files from your device to increase the amount of available storage space. If necessary, you can install the language files again later.
  1. Hold MENU.
  2. Select Settings > System > Language.
  3. Select a language.
  4. Select an option:
    • To remove the language file, select Delete.
    • To install the language file, select Install, connect the device to your computer using a USB cable, and sync with the Garmin Express™ application.
Copyright © Garmin. All rights reserved.GUID-DF83D4F4-0E7B-44D5-9F6C-59C20665AC00 v5
