Changing the GPS Setting
For more information about GPS, go to www.garmin.com/aboutGPS.
  1. Hold MENU.
  2. Select Settings > Activities & Apps.
  3. Select the activity to customize.
  4. Select the activity settings.
  5. Select GPS.
  6. Select an option:
    • Select Off to disable GPS for the activity.
    • Select Normal (GPS Only) to enable the GPS satellite system.
    • Select GPS + GLONASS (Russian satellite system) for more accurate position information in situations with poor sky visibility.
    • Select GPS + GALILEO (European Union satellite system) for more accurate position information in situations with poor sky visibility.
    • Select UltraTrac to record track points and sensor data less frequently (UltraTrac).
    NOTE: Using GPS and another satellite together can reduce battery life more quickly than using GPS only (GPS and Other Satellite Systems).
Copyright © Garmin. All rights reserved.GUID-DF83D4F4-0E7B-44D5-9F6C-59C20665AC00 v5
