Setting Your Heart Rate Zones
The device uses your user profile information from the initial setup to determine your default heart rate zones. You can set separate heart rate zones for sport profiles, such as running, cycling, and swimming. For the most accurate calorie data during your activity, set your maximum heart rate. You can also set each heart rate zone and enter your resting heart rate manually. You can manually adjust your zones on the device or using your Garmin Connect™ account.
  1. From the watch face, hold MENU.
  2. Select Settings > User Profile > Heart Rate.
  3. Select Max. HR, and enter your maximum heart rate.
  4. Select Resting HR, and enter your resting heart rate.
    You can use the average resting heart rate measured by your device, or you can set a custom resting heart rate.
  5. Select Zones > Based On.
  6. Select an option:
    • Select BPM to view and edit the zones in beats per minute.
    • Select %Max. HR to view and edit the zones as a percentage of your maximum heart rate.
    • Select %HRR to view and edit the zones as a percentage of your heart rate reserve (maximum heart rate minus resting heart rate).
  7. Select a zone, and enter a value for each zone.
  8. Select Sport Heart Rate, and select a sport profile to add separate heart rate zones (optional).
Copyright © Garmin. All rights reserved.GUID-DF83D4F4-0E7B-44D5-9F6C-59C20665AC00 v5
