Hull Features and Your In-Hull Transducer
An in-hull transducer bounces its sonar signal through a solid fiberglass hull. This is possible because fiberglass has sonar properties similar to water. For optimal results, you should observe the following recommendations with regard to your vessel's hull.
On single thickness fiberglass hulls up to 16 mm (5/8 in.), you can mount an in-hull transducer as flat as possible in the bilge (lowest area inside of the hull) near the transom.
You must mount the in-hull transducer over solid fiberglass, with no dead (hollow) space or core in the boat hull. In-hull transducers are not for use with metal, wood, or cored fiberglass hulls.
You can mount the in-hull transducer near the keel (centerline) if you ensure the keel does not block the signal or cause an echo.
You should not mount in-hull transducers over hull features that increase hull thickness beneath the device or over fittings, water intake or discharge ports that agitate the water.
An in-hull transducer performs well on power boats and sailboats when it is properly placed and installed.
You should verify the maximum deadrise angle for the transducer, which varies by model.
