Placement Considerations for In-Hull Transducers
NOTICE
To provide an optimal seal, read the instructions from the manufacturer of the mounting adhesive before using it. For secure adhesion, do not allow bubbles or voids to form in the mounting adhesive under the device. Since moisture can prevent the adhesive from curing, install the transducer during dry weather.
An in-hull transducer does not create drag or generate turbulence but is subject to interference from turbulence from other sources. You should test potential locations before mounting. Hull features are an important factor with this transducer type (Hull Features and Your In-Hull Transducer). General considerations include the following.
  • If installed over solid fiberglass with smooth water beneath the mounting area, the in-hull transducer type works well with any engine type.
  • An in-hull transducer can be installed while the boat is in the water.
  • Since air interferes with the transducer signal, do not allow bubbles or voids to form in the mounting adhesive under the device.
  • You should test possible placement locations while the boat is moving at low and high speeds, while checking depth readings, and use tape or a grease pencil to mark locations with the strongest signal.
    For information on how to test placement before mounting, check your transducer installation instructions or go to support.garmin.com.
GUID-D86E00AF-F9B3-497A-9F52-6EE1C2E12A51 v2
September 2026
