Adding Contacts
You can add up to 50 contacts to the Garmin Connect™ app. Contact emails can be used with the LiveTrack feature.
- From the Garmin Connect app, select .
- Follow the on-screen instructions.
After you add contacts, you must sync your data to apply the changes to your device (Manually Syncing Data with the Garmin Connect App).
Parent Topic: Turning On and Off LiveTrack
