Resetting the Device
Before you reset all default settings, you should sync the device with the Garmin Connect™ app to upload your activity data.
You can reset all of the device settings to the factory default values.
  1. From the Garmin Connect app, select Menu symbol > Garmin Devices.
  2. Select the CIRQA™ device.
  3. Select System > Reset.
  4. Select an option:
    • To reset all of the device settings to the factory default values, including user profile data, but save activity history and downloaded apps and files, select Reset Default Settings.
    • To reset all of the device settings to the factory default values and delete all user-entered information and activity history, select Delete Data and Reset Settings.
    The LED flashes Green Orange Red continuously, until the reset is complete.
    NOTE: Resetting the device can take up to 10 minutes.
  5. Pair again (Pairing Your Device with the Garmin Connect App).
GUID-D3BE589F-1A6C-4B6F-9ABC-07DB9AA6C739 v1
July 2026
