Wireless Sensors
Your Edge® bike computer can be paired and used with wireless sensors using ANT‍+® or Bluetooth® technology (Pairing Your Wireless Sensors). After the devices are paired, you can customize the optional data fields (Adding a Data Screen).
For information about specific Garmin® sensor compatibility, purchasing, or to view the owner's manual, go to garmin.com for that sensor.
Sensor Type
Description
eBike
You can use your device with your eBike, such as the Bosch® Smart System or Shimano® eBike system, and view bike data, such as battery and shifting information, during your rides (Viewing eBike Sensor Details).
Edge Remote
You can control your Edge bike computer with the Edge remote, including starting the activity timer, marking laps, and scrolling through data screens.
Extended Display
You can use the Extended Display mode to display data screens from your compatible Garmin watch on a compatible Edge bike computer during a ride or triathlon (Setting Up Extended Display Mode).
Heart Rate
You can use an external sensor, such as the HRM 200, HRM 600, HRM‍-Dual™, HRM‍-Fit™, or HRM-Pro™ series heart rate monitor, to view heart rate data during your activities.
You can also broadcast heart rate data from your Garmin compatible watch and view it on your paired Edge bike computer (Broadcasting Heart Rate Data).
inReach
The inReach® remote function allows you to control your inReach satellite communicator using your Edge bike computer (Using the inReach Remote).
Lights
You can use Varia™ smart bike lights to improve situational awareness. With a Varia headlight camera, you can also take photos and record video during a ride (Using the Varia Camera Controls).
Power
You can use the Rally™ or Vector™ power meter bike pedals to view power data on your device. You can adjust the power zones to match your goals and abilities (Setting Your Power Zones), or use range alerts to be notified when you reach a specified power zone (Setting Range Alerts).
Radar
You can use a Varia rearview bike radar to improve situational awareness and send alerts about approaching vehicles (Radar Data Screen). With a Varia radar camera tail light, you can also take photos and record video during a ride (Using the Varia Camera Controls).
Shifting
You can use electronic shifters to display shifting information during a ride. The Edge 1060 bike computer displays current adjustment values when the sensor is in adjustment mode.
TIP: You can program the action buttons of compatible electronic shifting systems to enable the OK Garmin voice command feature.
Shimano Di2
You can use Shimano Di2™ electronic shifters to display shifting information during a ride. The Edge 1060 bike computer displays current adjustment values when the sensor is in adjustment mode.
Smart Trainer
You can use your bike computer with an indoor bike smart trainer to simulate resistance while following a course, ride, or workout (Using an Indoor Trainer).
Speed/Cadence
You can attach speed or cadence sensors to your bike and view the data on your bike computer during your ride. If necessary, you can manually enter your wheel circumference (Wheel Size and Circumference).
Tempe
You can attach the tempe™ temperature sensor to a secure strap or loop where it is exposed to ambient air, so it provides a consistent source of accurate temperature data.
VIRB
The VIRB® remote function allows you to control your VIRB action camera using your bike computer.
GUID-D3621248-CC5B-4F04-B004-6F6FD9FDFEB0 v2
November 2026
