Updating Software with Garmin Express
You can use the Garmin Express™ application to download and install the latest software updates for your launch monitor.
  1. If you do not have the Garmin Express application installed on your computer, go to garmin.com/express and follow the on-screen instructions to install it.
  2. Open the Garmin Express application.
  3. Connect your launch monitor to your computer using a USB-C® cable.
  4. In the Garmin Express application, select Add a Device.
    The Garmin Express application searches for your launch monitor and displays the device name and serial number.
  5. Select Add Device, and follow the on-screen instructions to add your launch monitor to the Garmin Express application.
    When setup is complete, the Garmin Express application displays the updates available for your launch monitor.
  6. Select an option:
    • To install all available updates, click Install All.
    • To install a specific update, click View Details, and click Install next to the update you want.
    The Garmin Express application downloads and installs the updates onto your launch monitor.
  7. Follow the on-screen instructions during the update process to finish installing updates.
    For example, during the update process, the Garmin Express application may instruct you to disconnect and reconnect your device.
GUID-D31AA1A2-C026-46EB-9699-FA94F1E8AF0B v4
January 2026
