Heart Rate Accessory Running Pace and Distance
The HRM 600, HRM‍-Fit™, and HRM-Pro™ series accessories calculate your running pace and distance based on your user profile and the motion measured by the sensor on every stride. The heart rate monitor provides running pace and distance when GPS is not available, such as during treadmill running. You can view your running pace and distance on your compatible MARQ® watch when connected using ANT‍+® technology or secure Bluetooth® technology. You can also view it on compatible third-party training apps.
The pace and distance accuracy improves with calibration.
Automatic calibration
The default setting for your watch is Auto Calibrate. The heart rate accessory calibrates each time you run outside with it connected to your compatible MARQ watch.
NOTE: Automatic calibration does not work for indoor, trail, or ultra run activities (Tips for Recording Running Pace and Distance).
Manual calibration
You can select Calibrate & Save after a treadmill run with your connected heart rate accessory (Calibrating the Treadmill Distance).
GUID-CF6857C0-CEF9-485F-B3B4-B8DC192FA66A v9
August 2025
