Calibrating the Treadmill Distance
To record more accurate distances for your treadmill runs, you can calibrate the treadmill distance after you run at least 2.4 km (1.5 mi.) on a treadmill. If you use different treadmills, you can manually calibrate the treadmill distance on each treadmill or after each run.
  1. Start a treadmill activity (Starting an Activity).
  2. Run on the treadmill until your watch records at least 2.4 km (1.5 mi.).
  3. After you finish the activity, press STOP to stop the activity timer.
  4. Select an option:
    • To calibrate the treadmill distance the first time, select Save.
      The device prompts you to complete the treadmill calibration.
    • To manually calibrate the treadmill distance after the first-time calibration, select Calibrate & Save > Yes.
  5. Check the treadmill display for the distance traveled, and enter the distance on your watch.
GUID-CF6857C0-CEF9-485F-B3B4-B8DC192FA66A v9
August 2025
