Calibrating the Tack Assist
  1. From the watch face, select START.
  2. Select Sail Race or Sail.
  3. Select UP or DOWN to view the tack assist screen.
    NOTE: You may need to add the tack assist screen to the data screens for the activity (Customizing the Data Screens).
  4. Select START.
  5. Select an option:
    • To calibrate the starboard side, select START.
    • To calibrate the port side, select DOWN.
    TIP: If the wind is coming from the starboard side of the vessel, you should calibrate starboard. If the wind is coming from the port side of the vessel, you should calibrate port.
  6. Wait while the device calibrates the tack assist.
    An arrow appears and indicates if your boat is being lifted or headed.
GUID-CF6857C0-CEF9-485F-B3B4-B8DC192FA66A v9
August 2025
