Customizing the Data Screens
You can show, hide, and change the layout and content of data screens for each activity.
  1. Hold MENU.
  2. Select Activities & Apps.
  3. Select the activity to customize.
  4. Select the activity settings.
  5. Select Data Screens.
  6. Select a data screen to customize.
  7. Select an option:
    • Select Layout to adjust the number of data fields on the data screen.
    • Select Data Fields, and select a field to change the data that appears in the field.
      TIP: For a list of all the available data fields, go to Data Fields. Not all data fields are available for all activity types.
    • Select Reorder to change the location of the data screen in the loop.
    • Select Remove to remove the data screen from the loop.
  8. If necessary, select Add New to add a data screen to the loop.
    You can add a custom data screen, or select one of the predefined data screens.
GUID-CF6857C0-CEF9-485F-B3B4-B8DC192FA66A v9
August 2025
