Mounting Considerations
NOTICE
Selecting the correct mounting location is critical to optimize the performance of the remote control.
  • You must mount the remote control in a location that is within 10 m (33 ft.) of the stereo.
  • You must mount the remote control in a location where it is not submerged.
  • If you need to mount the remote control outside the boat, you should mount it in a location where it will not be damaged by docks, pilings, or other pieces of equipment.
  • You should select a flat mounting surface for the best results.
  • The mounting surface must be free of dirt, debris, wax, or coatings.
  • Do not mount the remote control higher than 2 m (6.5 ft.).
  • After you select the location, hold the remote control in the selected location, press a few buttons, and confirm the operation on the stereo.
  • Move away from sources that can interfere with the remote control's operation. Sources of interference may include strong electromagnetic fields, some 2.4 GHz wireless sensors, high-voltage power lines, electric motors, ovens, microwave ovens, 2.4 GHz cordless phones, and wireless LAN access points.
GUID-C750C64C-C518-4F7F-BF8B-D616628B827F v3
December 2024
