Radar Status LED
LED Activity
Status
Flashing blue
Bluetooth®
The device is in Bluetooth pairing mode. The light will flash for three minutes, until a Bluetooth device is paired, or until the device button is pressed.
Solid yellow
Demo
The device is in demo mode.
Solid orange
Error
The device is experiencing degraded performance because the rear sensor is obstructed.
Solid red
Error
The device is not operational because of a system error.
Solid blue to red
Normal operation
While traveling above 15 mph, colors progressively change from cool colors (blue, green) when the vehicle is around 70 m (229 ft.) away through to warm colors (yellow, orange, red) when the vehicle is around 9 m (29 ft.) away.
Solid blue
Normal operation
The device features are limited because the vehicle is traveling under 15 mph.
Single yellow flash (after button press)
Normal operation
The indicator lights are enabled, and radar detection is working.
Solid or flashing magenta
Update
The device is performing a software update and is disabled until the update is complete.
20 green flashes on startup
Update
The device performed a successful update.
20 red flashes on startup
Update
The device failed to perform a software update.
GUID-C6D73EE1-9FE0-494D-A2C7-BF02C3BEDDA6 v1
June 2026
