Setting an Alert
  1. Press Top button.
  2. Select More activities symbol.
  3. Select an activity.
  4. Select Settings symbol.
  5. Select the activity settings.
  6. Select Alerts.
  7. Select an option:
    • Select Add New to add a new alert for the activity.
    • Select the alert name to edit an existing alert.
  8. If necessary, select the type of alert.
  9. Select a zone, enter the minimum and maximum values, or enter a custom value for the alert.
  10. If necessary, turn on the alert.
For event and recurring alerts, a message appears each time you reach the alert value. For range alerts, a message appears each time you exceed or drop below the specified range (minimum and maximum values).
GUID-C3D54BBE-3966-4DA1-B60C-AD69DA5CC163 v2
October 2025
