Broadcasting Heart Rate Data
You can broadcast your heart rate data from your watch and view it on paired devices. Broadcasting heart rate data decreases battery life.
TIP: You can customize the activity settings to broadcast your heart rate data automatically when you begin an activity (Activity Settings). For example, you can broadcast your heart rate data to an Edge® bike computer while cycling.
  1. Select an option:
    • Press Line drawing of the watch with a top button callout, and select Settings > Health & Wellness > Wrist Heart Rate > Broadcast Heart Rate.
    • Hold Line drawing of the watch with a top button callout to open the controls menu, and select Heart rate broadcast symbol.
      NOTE: You can add options to the controls menu (Customizing the Controls Menu).
  2. Press Line drawing of the watch with a top button callout.
    The watch starts broadcasting your heart rate data.
  3. Pair your watch with your compatible device.
    NOTE: The pairing instructions differ for each Garmin® compatible device. See your owner's manual.
  4. Press Line drawing of the watch with a top button callout to stop broadcasting your heart rate data.
September 2026
