Customizing the Controls Menu
You can add, remove, and change the order of the shortcuts in the controls menu (Controls).
  1. Hold Line drawing of the watch with a top button callout.
    The controls menu appears.
  2. Swipe down.
  3. Select Edit.
  4. Select a shortcut:
    • To change the location of the shortcut in the controls menu, drag it to the desired location on the screen, and select Checkmark symbol.
    • To remove the shortcut from the controls menu, select Discard symbol.
  5. If necessary, select Add to add a shortcut to the controls menu.
GUID-C144B465-A0C8-4FE9-AFE6-41A3FE3F1D9A v6
November 2026
