Apps
You can customize your watch using the apps menu, which lets you quickly access watch features and options. Some apps require a Bluetooth® connection to a compatible phone. Many apps can also be found in the glances (Glances) or controls (Controls).
From the watch face, swipe left to view the apps list.
Name |
More Information |
ABC |
Select to view combined altimeter, barometer, and compass information. |
Alarms |
Select to set an alarm. |
Alt. Time Zones |
Displays the current time of day in additional time zones (Adding Alternate Time Zones). |
Altimeter |
Select to view altimeter information. |
Barometer |
Select to view barometer information. |
Broadcast Heart Rate |
Select to broadcast heart rate data to a paired device (Broadcasting Heart Rate Data). |
Calculator |
Select to use the calculator, including the tip calculator. |
Calendar |
Select to view upcoming events from your phone calendar. |
Clocks |
Select to set an alarm, timer, stopwatch, alternate time zone, or countdown event (Clocks). |
Compass |
Displays an electronic compass. |
Countdowns |
Displays upcoming countdown events. |
Garmin Share |
Select to send or receive data with other Garmin® devices (Garmin Share). |
Health Snapshot™ |
Select to record several key health metrics (Health Snapshot). |
History |
Select to view your recorded activity history, records, and totals (Using History). |
Map |
Select to view the map and navigate to a location (Navigating to a Destination). |
Map Manager |
Select to view and manage downloaded maps (Managing Maps). |
Messenger |
Select to view and send messages from the Garmin Messenger™ phone app (Garmin Messenger App). |
Moon Phase |
Select to view the moonrise and moonset times, along with the moon phase, based on your GPS position. |
Music |
Select to control audio playback using your watch (Listening to Music). |
Notifications |
Select to view your phone notifications (Viewing Notifications). |
Nutrition |
Select to track your daily nutrition, including calories and macronutrients. You can also log your food intake. You must have an active Garmin Connect+™ subscription to track and view your nutrition (Garmin Connect+ Subscription). |
Phone |
Select to open the phone controls, such as contacts and the dial pad (Calling from the Phone App). |
Phone Assistant |
Select to speak a command for your phone's voice assistant (Using the Phone Assistant). |
Pulse Ox |
Select to take a pulse oximeter reading (Pulse Oximeter). |
Saved |
Select to view your saved locations, courses, and waypoints. |
Settings |
Select to open the settings menu. |
Sports Scores |
Select to track college or professional sports teams with scores and live data. |
Stocks |
Select to view a customizable list of stocks (Adding a Stock). |
Stopwatch |
Select to use the stopwatch. |
Sunrise & Sunset |
Select to view sunrise, sunset, and twilight times. |
Timers |
Select to set a timer. |
Tips |
Select to view interactive watch tips, learn about new features on your watch, and scan a direct link to support.garmin.com to access the owner's manual for your watch. |
Voice Command |
Select to speak a command for your watch to perform (Using Voice Commands). |
Voice Notes |
Select to record a voice note (Recording a Voice Note). |
Wallet |
Select to open your Garmin Pay™ wallet (Garmin Pay). |
Watch Face |
Select to customize your watch face (Customizing the Watch Face). |
Weather |
Select to view the current weather forecast and conditions. |
Workouts |
Select to view your saved workouts (Workouts). |
