Apps
You can customize your watch using the apps menu, which lets you quickly access watch features and options. Some apps require a Bluetooth® connection to a compatible phone. Many apps can also be found in the glances (Glances) or controls (Controls).
From the watch face, swipe left to view the apps list.
Activities menu data
Name
More Information
ABC
Select to view combined altimeter, barometer, and compass information.
Alarms
Select to set an alarm.
Alt. Time Zones
Displays the current time of day in additional time zones (Adding Alternate Time Zones).
Altimeter
Select to view altimeter information.
Barometer
Select to view barometer information.
Broadcast Heart Rate
Select to broadcast heart rate data to a paired device (Broadcasting Heart Rate Data).
Calculator
Select to use the calculator, including the tip calculator.
Calendar
Select to view upcoming events from your phone calendar.
Clocks
Select to set an alarm, timer, stopwatch, alternate time zone, or countdown event (Clocks).
Compass
Displays an electronic compass.
Connect IQ™
Select to use the Connect IQ store on your watch (Connect IQ Features).
Countdowns
Displays upcoming countdown events.
Garmin Share
Select to send or receive data with other Garmin® devices (Garmin Share).
Health Snapshot™
Select to record several key health metrics (Health Snapshot).
History
Select to view your recorded activity history, records, and totals (Using History).
Lifestyle Logging
Select to track your day-to-day behaviors, and see how the behaviors affect certain health metrics in the Garmin Connect™ app (Lifestyle Logging).
Map
Select to view the map and navigate to a location (Navigating to a Destination).
Map Manager
Select to view and manage downloaded maps (Managing Maps).
Messenger
Select to view and send messages from the Garmin Messenger™ phone app (Garmin Messenger App).
Moon Phase
Select to view the moonrise and moonset times, along with the moon phase, based on your GPS position.
Music
Select to control audio playback using your watch (Listening to Music).
Notifications
Select to view your phone notifications (Viewing Notifications).
Nutrition
Select to track your daily nutrition, including calories and macronutrients. You can also log your food intake. You must have an active Garmin Connect+ subscription to track and view your nutrition (Garmin Connect+ Subscription).
Phone
Select to open the phone controls, such as contacts and the dial pad (Calling from the Phone App).
Phone Assistant
Select to speak a command for your phone's voice assistant (Using the Phone Assistant).
Pulse Ox
Select to take a pulse oximeter reading (Pulse Oximeter).
Reference Point
Select to set a reference point to provide the heading and distance to a location or bearing (Setting a Reference Point).
Saved
Select to view your saved locations, courses, and waypoints.
Settings
Select to open the settings menu.
Sports Scores
Select to track college or professional sports teams with scores and live data.
Stocks
Select to view a customizable list of stocks (Adding a Stock).
Stopwatch
Select to use the stopwatch.
Sunrise & Sunset
Select to view sunrise, sunset, and twilight times.
Timers
Select to set a timer.
Tips
Select to view interactive watch tips, learn about new features on your watch, and scan a direct link to support.garmin.com to access the owner's manual for your watch.
Voice Command
Select to speak a command for your watch to perform (Using Voice Commands).
Voice Notes
Select to record a voice note (Recording a Voice Note).
Wallet
Select to open your Garmin Pay™ wallet (Garmin Pay).
Watch Face
Select to customize your watch face (Customizing the Watch Face).
Weather
Select to view the current weather forecast and conditions.
Weight Tracking
Select to view your recent weight trends and history. You can enter your weight manually. If you have an Index™ scale paired to your Garmin Connect account, your weight data appears in the app.
Workouts
Select to view your saved workouts (Workouts).
September 2026
