Managing Maps
  1. From the watch face, swipe left.
  2. Select Settings > Map & Navigation > Map Manager.
  3. Select an option:
Downloading Maps with Outdoor Maps+
Before you can download maps to your device, you must connect to a wireless network (Connecting to a Wi‑Fi Network).
  2. Select Settings > Map & Navigation > Map Manager > Outdoor Maps+.
  3. If necessary, press Line drawing of the watch with a top button callout, and select Check Subscription to activate your Outdoor Maps+ subscription for this watch.
    NOTE: Go to garmin.com/outdoormaps for information about purchasing a subscription.
  4. Select Add Map, and select a location.
    A preview of the map region appears.
  5. From the map, complete one or more actions:
    • Drag the map to view different areas.
    • Pinch or spread two fingers on the touchscreen to zoom in and out of the map.
    • Select Plus symbol and Minus symbol to zoom in and out of the map.
  6. Press Line drawing of the watch with a bottom button callout, and select Checkmark symbol.
  7. Select Edit symbol.
  8. Select an option:
    • To edit the map name, select Name.
    • To change the map layers to download, select Layers.
      TIP: You can select More information to view details about the map layers.
    • To modify the map region, select Selected Area.
  9. Select Checkmark symbol to download the map.
    NOTE: To prevent battery drain, the watch queues the map download for later, and the download starts when you connect the watch to an external power source.
Downloading TopoActive Maps
  2. Select Settings > Map & Navigation > Map Manager > TopoActive Maps > Add Map.
  3. Select a map.
  4. Press Line drawing of the watch with a top button callout, and select Download.
Deleting Maps
You can remove maps to increase the available device storage.
    • Select TopoActive Maps, select a map, press Line drawing of the watch with a top button callout, and select Remove.
    • Select Outdoor Maps+, select a map, press Line drawing of the watch with a top button callout, and select Delete.
GUID-C144B465-A0C8-4FE9-AFE6-41A3FE3F1D9A v6
November 2026
