Altimeter and Barometer
The watch contains an internal altimeter and barometer. The watch collects elevation and pressure data continuously, even in low-power mode. The altimeter displays your approximate elevation based on pressure changes. The barometer displays environmental pressure data based on the fixed elevation where the altimeter was most recently calibrated (Altimeter and Barometer Settings). You can select Menu symbol from the altimeter or barometer glances to open the altimeter or barometer settings quickly. You can view the altimeter and barometer from the controls menu (Controls), glances list (Glances), or apps list (Apps).
September 2026
