Flush Mounting
NOTICE
Be careful when cutting the hole to flush mount the device. There is only a small amount of clearance between the case and the mounting holes, and cutting the hole too large could compromise the stability of the device after it is mounted.
NOTICE
Use only the included hardware when mounting this device. Using mounting hardware not provided with the device may damage the device.
NOTICE
To avoid potential damage to the device housing, use only the included screws to mount the device. Using screws other than the ones included will void your warranty.
NOTICE
Do not use the device as a template when drilling the mounting holes because this may damage the glass display and void the warranty. You must only use the included template to correctly drill the mounting holes.
NOTICE
If you will not have access to the back of the device and the microSD® memory card slots after installations, you should install the microSD memory card prior to installation.
The included template and hardware can be used to flush mount the device in your dashboard. There are three options for hardware based on the mounting surface material.
  • You can drill pilot holes and use the included wood screws.
  • You can punch and tap holes, and use the included machine screws.
  • You can drill holes and use the included nut plates and machine screws. The nut plates can add stability to a thinner mounting surface.
GUID-BF2FF273-008A-482A-A96F-362ADA8996BA v8
January 2025
