Flush Mounting the Device Using Wood or Metal Screws
Before you can secure the device to the mounting surface using wood or metal screws, you must cut an opening for the device and confirm or mark the locations of the mounting holes.
  1. Using a drill bit according to the table below, drill or drill and tap the larger holes indicated on the template.
    Device
    Drill bit size
    GPSMAP® 7x3, GPSMAP 9x3, and GPSMAP 12x3
    Wood screws (drill): 2.3 mm (3/32 in.)
    Metal screws (drill and tap): M3
    GPSMAP 16x3
    Wood screws (drill): 3.2 mm (1/8 in.)
    Metal screws (drill and tap): M4
  2. Install the foam gasket on the back of the device.
    The pieces of the foam gasket have adhesive on the back. Make sure you remove the protective liner before installing them on the device.
  3. If you will not have access to the back of the device after you mount it, connect all necessary cables and install microSD® cards in the back of the device before placing it into the cutout.
    NOTICE
    To prevent corrosion of the metal contacts, cover unused connectors with the attached weather caps.
  4. Apply marine sealant between the mounting surface and the device to properly seal and prevent leakage behind the dashboard.
  5. If you will have access to the back of the device, apply marine sealant around the cutout.
  6. Place the device into the cutout.
  7. Secure the device to the mounting surface using the included flat head machine screws or the included wood screws.
  8. Wipe away all excess marine sealant.
  9. Install the trim caps by snapping them in place around the edges of the device.
GUID-BF2FF273-008A-482A-A96F-362ADA8996BA v8
January 2025
