NMEA 2000 Considerations
NOTICE
If you are connecting to an existing NMEA 2000® network, identify the NMEA 2000 power cable. Only one NMEA 2000 power cable is required for the NMEA 2000 network to operate properly.
A NMEA 2000 Power Isolator (010-11580-00) should be used in installations where the existing NMEA 2000 network manufacturer is unknown.
NOTICE
If you are installing a NMEA 2000 power cable, you must connect it to the boat ignition switch or through another in-line switch. NMEA 2000 devices will drain your battery if the NMEA 2000 power cable is connected to the battery directly.
This device can connect to a NMEA 2000 network on your boat to share data from NMEA 2000 compatible devices such as a GPS antenna or a VHF radio. The included NMEA 2000 cables and connectors allow you to connect the device to your existing NMEA 2000 network. If you do not have an existing NMEA 2000 network you can create a basic one using cables from Garmin®.
This device is not powered through the NMEA 2000 network. You must connect the device to a power source (Connecting the Wiring Harness to Power).
If you are unfamiliar with NMEA 2000, you should read the Technical Reference for NMEA 2000 Products at garmin.com/manuals/nmea_2000.
The port labeled NMEA 2000 is used to connect the device to a standard NMEA 2000 network.
Wiring diagram with callouts
Item
Description
Callout number 1
NMEA 2000 compatible Garmin device
Callout number 2
GPS antenna
Callout number 3
Ignition or in-line switch
Callout number 4
Callout number 5
NMEA 2000 drop cable
Callout number 6
12 Vdc power source
Callout number 7
NMEA 2000 terminator or backbone cable
Callout number 8
NMEA 2000 T-connector
Callout number 9
GUID-BF2FF273-008A-482A-A96F-362ADA8996BA v8
January 2025
