Controls
The controls menu lets you quickly access watch features and options. You can add, reorder, and remove the options in the controls menu (Customizing the Controls Menu).
From any screen, hold CTRL.
Screenshot of the controls menu
Icon
Name
Description
Altimeter, barometer, and compass
ABC
Select to open the altimeter, barometer, and compass app.
Alarm clock
Alarm Clock
Select to add or edit an alarm (Setting an Alarm).
Alternate time zones
Alt. Time Zones
Select to view the current time of day in additional time zones (Adding Alternate Time Zones).
Altimeter
Altimeter
Select to open the altimeter screen.
Applied Ballistics
Applied Ballistics
Select to open the Applied Ballistics app (Applied Ballistics).
NOTE: This feature is available only on Instinct® Crossover AMOLED - Tactical Edition models.
Assistance
Assistance
Select to send an assistance request (Requesting Assistance).
Barometer
Barometer
Select to open the barometer screen.
Battery saver
Battery Saver
Select to enable the battery saver feature (Customizing the Battery Saver Feature).
Brightness
Brightness
Select to adjust the screen brightness (Changing the Screen Settings).
Broadcast heart rate data
Broadcast Heart Rate
Select to turn on heart rate broadcasting to a paired device (Broadcasting Heart Rate Data).
Calendar
Calendar
Select to view upcoming events from your phone calendar.
Clocks
Clocks
Select to open the Clocks app to set an alarm, timer, stopwatch, or view alternate time zones (Clocks).
Compass
Compass
Select to open the compass screen.
Display on or off
Display
Select to turn off the screen for alerts, gestures, and Always On Display mode (Changing the Screen Settings).
Do not disturb
Do Not Disturb
Select to enable do not disturb mode to dim the screen and disable alerts and notifications. For example, you can use this mode while watching a movie.
Find my phone
Find My Phone
Select to play an audible alert on your paired phone, if it is within Bluetooth® range. The Bluetooth signal strength appears on the Instinct watch screen, and it increases as you move closer to your phone.
Garmin Share
Garmin Share
Select to open the Garmin Share app (Garmin Share).
History
History
Select to view your activity history, records, and totals.
Lock
Lock Device
Select to lock the buttons to prevent inadvertent presses.
Messenger
Messenger
Select to view and send messages using the Messenger app (Using the Messenger Feature).
Moon phase
Moon Phase
Select to view moonrise and moonset times, along with the moon phase, based on your GPS position.
Music
Music Controls
Select to control music playback on your phone.
Night vision
Night Vision
Select to adjust the screen for compatibility with night vision goggles and disable the wrist heart rate monitor.
NOTE: This feature is available only on Instinct Crossover AMOLED - Tactical Edition models.
Notifications
Notifications
Select to view calls, texts, social network updates, and more, based on your phone notification settings (Enabling Bluetooth Notifications).
Phone
Phone
Select to disable Bluetooth technology and your connection to your paired phone.
Power off
Power Off
Select to turn off the watch.
Pulse oximeter
Pulse Ox
Select to open the pulse oximeter app (Pulse Oximeter).
Red shift
Red Shift
Select to turn the screen to shades of red to use the watch in low light conditions.
Reference point
Reference Point
Select to set a reference point for navigation (Setting a Reference Point).
Save location
Save Location
Select to save your current location to navigate back to it later (Using the Saved App).
Settings
Settings
Select to open the settings menu.
Sleep mode
Sleep Mode
Select to enable or disable Sleep Mode (Customizing Sleep Mode).
Stealth mode
Stealth Mode
Select to enable stealth mode to turn off wireless communications and prevent the storage and sharing of your GPS position.
Stopwatch
Stopwatch
Select to start the stopwatch (Using the Stopwatch).
Strobe
Strobe
Select to turn on the LED flashlight strobe. You can create a custom strobe mode.
Sunrise and sunset
Sunrise & Sunset
Select to view sunrise, sunset, and twilight times.
Sync
Sync
Select to sync your watch with your paired phone.
Time sync
Time Sync
Select to sync your watch with the time on your phone or using satellites.
Timers
Timers
Select to set a countdown timer (Using a Countdown Timer).
Flashlight
Torch
Select to turn on the LED flashlight (Using the Torch).
Wallet
Wallet
Select to open your Garmin Pay™ wallet and pay for purchases with your watch (Garmin Pay).
Weather
Weather
Select to view the current weather forecast and current conditions.
GUID-B613EA0B-EFB7-451C-BA10-DB9EE5A990BF v4
September 2026
